Saltar al contenido principal
Acer Aspire 4520-5464 RAM Replacement
Qué necesitas
  1. Acer Aspire 4520-5464 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 RAM Replacement: paso 2, imagen 1 de 2 Acer Aspire 4520-5464 RAM Replacement: paso 2, imagen 2 de 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 RAM Replacement: paso 3, imagen 1 de 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 RAM Replacement, RAM: paso 4, imagen 1 de 2 Acer Aspire 4520-5464 RAM Replacement, RAM: paso 4, imagen 2 de 2
    • Remove the seven 2mm Phillips #1 screws from the largest panel on back of the laptop.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 RAM Replacement: paso 5, imagen 1 de 3 Acer Aspire 4520-5464 RAM Replacement: paso 5, imagen 2 de 3 Acer Aspire 4520-5464 RAM Replacement: paso 5, imagen 3 de 3
    • Push the white tabs located on either side of the top stick of RAM outward.
    • Remove the RAM from the slot on the motherboard.
    • Repeat for the bottom stick of RAM.
Conclusión
Una persona más ha completado esta guía.
Un comentario
interesting good job
Maren Eras - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 1,234
