Saltar al contenido principal
Acer Aspire 4520-5464 Keyboard Replacement
Qué necesitas
  1. Acer Aspire 4520-5464 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Keyboard Replacement: paso 2, imagen 1 de 2 Acer Aspire 4520-5464 Keyboard Replacement: paso 2, imagen 2 de 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Keyboard Replacement: paso 3, imagen 1 de 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Remove the five 1mm Phillips #1 screws located inside of the battery compartment.
    • Remove the three 2mm Phillips #1 screws located at the top of the case's perimeter.
  5. Acer Aspire 4520-5464 Keyboard Replacement: paso 5, imagen 1 de 2 Acer Aspire 4520-5464 Keyboard Replacement: paso 5, imagen 2 de 2
    • Remove the gray plastic section located above the keyboard using the prying tool.
    • Lift off of the keyboard.
  6. Acer Aspire 4520-5464 Keyboard Replacement: paso 6, imagen 1 de 2 Acer Aspire 4520-5464 Keyboard Replacement: paso 6, imagen 2 de 2
    • Take hold of the keyboard behind the function keys and lift gently.
    • Do not completely separate the keyboard from the laptop.
  7. Acer Aspire 4520-5464 Keyboard Replacement: paso 7, imagen 1 de 2 Acer Aspire 4520-5464 Keyboard Replacement: paso 7, imagen 2 de 2
    • Lift up the black locking tab located where the keyboard is attached to the laptop.
    • Pull the keyboard cable towards the trackpad and remove the keyboard.
Conclusión
To reassemble your device, follow these instructions in reverse order using your new keyboard.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 14
Todo El Tiempo: 602
