Saltar al contenido principal
Acer Aspire 4520-5464 Hard Drive Replacement
Qué necesitas
  1. Acer Aspire 4520-5464 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Hard Drive Replacement: paso 2, imagen 1 de 2 Acer Aspire 4520-5464 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 3 Acer Aspire 4520-5464 Hard Drive Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Remove the seven 2mm Phillips #1 screws from the largest panel on the back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Hard Drive Replacement: paso 5, imagen 1 de 3 Acer Aspire 4520-5464 Hard Drive Replacement: paso 5, imagen 2 de 3 Acer Aspire 4520-5464 Hard Drive Replacement: paso 5, imagen 3 de 3
    • Remove the two 0.5mm Phillips #1 black screws left of the Hard Drive.
    • Remove the two 0.5mm Phillips #1 silver on top of the Hard Drive.
    • Lift up and remove the hard drive bracket by the plastic tab on top of the hard drive.
  6. Acer Aspire 4520-5464 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Remove the hard drive from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 825
