Saltar al contenido principal
Acer Aspire 4520-5464 Graphics Card Replacement
Qué necesitas
  1. Acer Aspire 4520-5464 Graphics Card Replacement, Battery: paso 1, imagen 1 de 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Graphics Card Replacement: paso 2, imagen 1 de 2 Acer Aspire 4520-5464 Graphics Card Replacement: paso 2, imagen 2 de 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Graphics Card Replacement: paso 3, imagen 1 de 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: paso 4, imagen 1 de 3 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: paso 4, imagen 2 de 3 Acer Aspire 4520-5464 Graphics Card Replacement, Graphics Card: paso 4, imagen 3 de 3
    • Using a Phillips PH1 screwdriver, remove the seven 0.5mm screws from the largest panel on the back of the laptop.
    • Set the screws aside.
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 Graphics Card Replacement: paso 5, imagen 1 de 1
    • Unscrew the four 0.5mm Phillips #1 screws located on the heat sink in numerical order, as labeled on the device.
  6. Acer Aspire 4520-5464 Graphics Card Replacement: paso 6, imagen 1 de 1
    • Using the traditional 2.5mm screwdriver, rotate the locking tab counterclockwise to unlock the graphics card.
  7. Acer Aspire 4520-5464 Graphics Card Replacement: paso 7, imagen 1 de 2 Acer Aspire 4520-5464 Graphics Card Replacement: paso 7, imagen 2 de 2
    • Lift up the heat sink line and remove the graphics card.
Conclusión
2 personas más completaron esta guía.
Un comentario
This is a CPU slot not slot of Graphics Card! The replacement of GPU for this model is Soldered
Fernando Rodrigues - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 25
Todo El Tiempo: 2,374
