Saltar al contenido principal
Acer Aspire 4520-5464 CD/DVD Drive Replacement
Qué necesitas
  1. Acer Aspire 4520-5464 CD/DVD Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 CD/DVD Drive Replacement: paso 2, imagen 1 de 2 Acer Aspire 4520-5464 CD/DVD Drive Replacement: paso 2, imagen 2 de 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 CD/DVD Drive Replacement: paso 3, imagen 1 de 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: paso 4, imagen 1 de 3 Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: paso 4, imagen 2 de 3 Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: paso 4, imagen 3 de 3
    • Remove 7 of the 2mm Phillips #1 screw from the largest panel on back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 CD/DVD Drive Replacement: paso 5, imagen 1 de 1
    • Remove the .5mm Phillips #1 black screw located on the left side of the panel opening.
  6. Acer Aspire 4520-5464 CD/DVD Drive Replacement: paso 6, imagen 1 de 2 Acer Aspire 4520-5464 CD/DVD Drive Replacement: paso 6, imagen 2 de 2
    • Using the screwdriver, push the CD drive out of the laptop through the panel exposure.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 14
Todo El Tiempo: 419
