Saltar al contenido principal
Acer Aspire 4520-5464 Battery Replacement
  1. Acer Aspire 4520-5464 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 Battery Replacement: paso 2, imagen 1 de 2 Acer Aspire 4520-5464 Battery Replacement: paso 2, imagen 2 de 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 Battery Replacement: paso 3, imagen 1 de 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
Conclusión
To reassemble your device, follow these instructions in reverse order using a new battery.
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 11
Todo El Tiempo: 438
