Saltar al contenido principal
Acer Aspire 3000 RAM Replacement
Qué necesitas
  1. Acer Aspire 3000 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 RAM Replacement: paso 2, imagen 1 de 2 Acer Aspire 3000 RAM Replacement: paso 2, imagen 2 de 2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 RAM Replacement: paso 3, imagen 1 de 2 Acer Aspire 3000 RAM Replacement: paso 3, imagen 2 de 2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Unscrew the two 4.6 mm Phillips #1 screws found at the bottom of the RAM cover using the phillips head j1 bit.
  5. Acer Aspire 3000 RAM Replacement: paso 5, imagen 1 de 1
    • Open the RAM cover by wedging the opening tool and the metal spudger in the opening between the two screws.
  6. Acer Aspire 3000 RAM Replacement: paso 6, imagen 1 de 1
    • Slide the opening tool around the sides of the cover to release the 3 tabs that hold the cover down.
  7. Acer Aspire 3000 RAM Replacement: paso 7, imagen 1 de 1
    • Lift and pull the cover back towards you to detach it from the device.
  8. Acer Aspire 3000 RAM Replacement: paso 8, imagen 1 de 1
    • Push the white tabs on either side away from the from the chip.
    • The chip should be released upward automatically after pushing the tabs.
  9. Acer Aspire 3000 RAM Replacement: paso 9, imagen 1 de 1
    • Pull and lift the chip to release it from the RAM port.
  10. Acer Aspire 3000 RAM Replacement: paso 10, imagen 1 de 1
    • Repeat step 9 to release the bottom chip from its RAM port.
Conclusión
2 personas más completaron esta guía.
roro6730
Miembro Desde 10/30/16
351 Reputación
2 Guías creadas
Equipo
Baylor, Team 4-2, Williams Fall 2016 Miembro de Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 715
