Saltar al contenido principal
Acer Aspire 3 A315-21-92FX Speakers Replacement
Qué necesitas
  1. Acer Aspire 3 A315-21-92FX Speakers Replacement, RAM: paso 1, imagen 1 de 1
    • Flip the Acer Aspire 3 A315-21-92FX over so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 2, imagen 1 de 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 2, imagen 2 de 2
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 3, imagen 1 de 1
    • Use the iFixit opening tool to remove the small cover.
  4. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 4, imagen 1 de 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 4, imagen 2 de 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 4, imagen 3 de 3
    • Press the tabs on each side of the RAM outwards, and the memory module will pop up at an angle.
  5. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 5, imagen 1 de 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 5, imagen 2 de 2
    • Pull the RAM slowly out of the Acer Aspire 3 A315-21-92FX.
  6. Acer Aspire 3 A315-21-92FX Speakers Replacement, Hard Drive: paso 6, imagen 1 de 1
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  7. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 7, imagen 1 de 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 7, imagen 2 de 2
  8. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 8, imagen 1 de 1
    • Use the iFixit opening tool to remove the cover of the hard disk.
  9. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 9, imagen 1 de 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 9, imagen 2 de 2
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
  10. Acer Aspire 3 A315-21-92FX Speakers Replacement, Battery: paso 10, imagen 1 de 1
    • Remove fourteen 2.5mm Phillips #0 screws from the back of the laptop.
    • There may be two additional screws under the hard drive cover that must be removed before attempting to remove the back cover.
  11. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 11, imagen 1 de 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 11, imagen 2 de 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 11, imagen 3 de 3
    • Use the iFixit opening tool to remove the back cover.
  12. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 12, imagen 1 de 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 12, imagen 2 de 2
    • Pull out the plug connecting the battery to the motherboard.
  13. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 13, imagen 1 de 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 13, imagen 2 de 2
    • Pull the battery out of the groove.
  14. Acer Aspire 3 A315-21-92FX Speakers Replacement, Speakers: paso 14, imagen 1 de 1
    • Remove the speaker located in the right hand of the device first using the iFixit Opening Tool.
    • Place the edge of the iFixit Opening Tool under the speaker and pull it upward.
  15. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 15, imagen 1 de 1
    • Remove the speaker from the left side of the computer using the iFixit Opening Tool.
  16. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 16, imagen 1 de 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 16, imagen 2 de 2
    • The cable that is connecting the speakers to the motherboard is placed under these plastic cables that are glued to the computer.
    • Remove these glued cables using the iFixit Opening Tool.
  17. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 17, imagen 1 de 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 17, imagen 2 de 3 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 17, imagen 3 de 3
    • Detach the speaker connector from the motherboard with your fingers or the iFixit Opening Tool.
  18. Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 18, imagen 1 de 2 Acer Aspire 3 A315-21-92FX Speakers Replacement: paso 18, imagen 2 de 2
    • Remove the speakers with your hands.
Conclusión
3 personas más completaron esta guía.
gghhh
Miembro Desde 01/14/20
329 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 1,497
