Saltar al contenido principal
Acer Aspire 3 A315-21-92FX Hard Drive Replacement
Qué necesitas
  1. Acer Aspire 3 A315-21-92FX Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: paso 2, imagen 1 de 2 Acer Aspire 3 A315-21-92FX Hard Drive Replacement: paso 2, imagen 2 de 2
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: paso 3, imagen 1 de 1
    • Use the iFixit opening tool to remove the cover of the hard disk.
  4. Acer Aspire 3 A315-21-92FX Hard Drive Replacement: paso 4, imagen 1 de 2 Acer Aspire 3 A315-21-92FX Hard Drive Replacement: paso 4, imagen 2 de 2
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
Conclusión
4 personas más completaron esta guía.
ShengKun Lu
Miembro Desde 01/14/20
705 Reputación
3 Guías creadas
Equipo
2 comentarios
My acer aspire 3 A315-32 says no bootable device I had tried to boot Linux from USB but I partioned the hard drive so I fixed it by changing the format and deleting everything and installed windows on a different pc but it’s still not booting even on boot options it’s not showing
Zeek tuyishime - Contestar
These connecting cable is missing, where to buy these cable. Pls tell the cable name
jayesh v v - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 25
Ultimos 30 días: 77
Todo El Tiempo: 6,245
