Introducción
Use this guide to replace the battery on an Accusplit Pro Survivor A601X stopwatch.
As is the case in any electronical device, the battery will either die or become corroded after a long time. If you notice your stopwatch has stopped working, the battery likely needs replacement. This guide will demonstrate how to access and replace the battery without damaging the rest of the watch.
Qué necesitas
Unscrew the back of the watch with a Phillip’s head #0, 2.5 millimeter screwdriver.
