Saltar al contenido principal
Accessing Samsung ML2510 Circuit Board
Qué necesitas
  1. Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: paso 1, imagen 1 de 3 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: paso 1, imagen 2 de 3 Accessing Samsung ML2510 Circuit Board, Removing Samsung ML2510 Back Panel: paso 1, imagen 3 de 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Accessing Samsung ML2510 Circuit Board: paso 2, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Accessing Samsung ML2510 Circuit Board: paso 3, imagen 1 de 3 Accessing Samsung ML2510 Circuit Board: paso 3, imagen 2 de 3 Accessing Samsung ML2510 Circuit Board: paso 3, imagen 3 de 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: paso 4, imagen 1 de 3 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: paso 4, imagen 2 de 3 Accessing Samsung ML2510 Circuit Board, Accessing Samsung ML2510 Circuit Board: paso 4, imagen 3 de 3
    • Remove the front panel by gently freeing the holes on the panel from the pegs attached to the main printer body one at a time. Make sure to remove the entire front panel, not just the flap on the paper tray.
  5. Accessing Samsung ML2510 Circuit Board: paso 5, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Accessing Samsung ML2510 Circuit Board: paso 6, imagen 1 de 3 Accessing Samsung ML2510 Circuit Board: paso 6, imagen 2 de 3 Accessing Samsung ML2510 Circuit Board: paso 6, imagen 3 de 3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Accessing Samsung ML2510 Circuit Board: paso 7, imagen 1 de 3 Accessing Samsung ML2510 Circuit Board: paso 7, imagen 2 de 3 Accessing Samsung ML2510 Circuit Board: paso 7, imagen 3 de 3
    • Lift the right panel up from the raised stops.
    • Rotate the panel gently as indicated in the picture to remove the panel entirely.
  8. Accessing Samsung ML2510 Circuit Board: paso 8, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the four 1" screws attaching the gray plate to the printer.
    • Remove the plastic cover by sliding it carefully under the silver hinges on the right.
  9. Accessing Samsung ML2510 Circuit Board: paso 9, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the 1" screw attaching the circuit board to the printer.
  10. Accessing Samsung ML2510 Circuit Board: paso 10, imagen 1 de 2 Accessing Samsung ML2510 Circuit Board: paso 10, imagen 2 de 2
    • Turn over the circuit board to access main wiring.
    • Unplug the wiring from the circuit board gently.
Conclusión
3 personas más completaron esta guía.
bbaustin
Miembro Desde 10/12/11
268 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-18, Regan Fall 2011 Miembro de Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 11
Todo El Tiempo: 2,839
