Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
The Nokia 3100b may not vibrate anymore when the phone is set in Vibrate mode. This guide will show you how to access the vibrating unit.
Partes
No se especificaron partes.
  1. Make sure your phone is turned off.
    • Make sure your phone is turned off.
  2. Press the button on the back of the phone and slide the back panel off.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Note the small metal frame that  hold the SIM card into place.
    • Note the small metal frame that hold the SIM card into place.
    • Gently pull back the tab and lift open the frame.
  4. Retrieve your SIM card.
    • Retrieve your SIM card.
  5. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Separate the front cover from the base of the phone.
    • Separate the front cover from the base of the phone.
    • Set the front cover, as indicated, aside.
  7. Remove the screws indicated using a T6 Torx screwdriver.
    • Remove the screws indicated using a T6 Torx screwdriver.
    • Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
  8. Separate the screen assembly from the base of the phone.
    • Separate the screen assembly from the base of the phone.
    • Set the screen assembly, as indicated, aside.
  9. The vibrating unit can now be accessed. Note its location in the phone.
    • The vibrating unit can now be accessed. Note its location in the phone.
  10. The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
    • The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
  11. The vibrating unit is now removed.
    • The vibrating unit is now removed.
Conclusión
Equipo
Cal Poly, Team 29-64, Johann Spring 2010 Miembro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,526
