Introducción
In this guide you will learn how to remove the SD card circuit board to access the logic board. To access the logic board, you will need to unsolder two leads. For soldering instructions, please refer to steps 1 through 6 of this soldering guide.
Qué necesitas
Remove the following screws:
Two silver 3.15mm Phillips #00 screws on the right side of the camera
Two silver 2.08mm Phillips #00 screws on the left side of the camera
On the front of the camera, in battery case, remove screws indicated:
Two black 2.05mm Phillips #00 screws
