Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Accessing LCD Screen
Qué necesitas
    1. Accessing LCD Screen, Front and Back Cover: paso 1, imagen 1 de 2 Accessing LCD Screen, Front and Back Cover: paso 1, imagen 2 de 2
      • Remove the following screws:
      • Two silver 3.15mm Phillips #00 screws on the right side of the camera
      • Two silver 2.08mm Phillips #00 screws on the left side of the camera
      Pregunta a FixBot
      Agregar Comentario
    2. Accessing LCD Screen: paso 2, imagen 1 de 1
      • Remove the two indicated screws on the bottom of the camera:
      • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
      • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
      Pregunta a FixBot
      Agregar Comentario
    3. Accessing LCD Screen: paso 3, imagen 1 de 2 Accessing LCD Screen: paso 3, imagen 2 de 2
      • Carefully pull the back of casing away from the front.
      Pregunta a FixBot
      Agregar Comentario
    4. Accessing LCD Screen: paso 4, imagen 1 de 3 Accessing LCD Screen: paso 4, imagen 2 de 3 Accessing LCD Screen: paso 4, imagen 3 de 3
      • After removing the back cover, several things must be removed.
      • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
      Pregunta a FixBot
      Agregar Comentario
    5. Accessing LCD Screen: paso 5, imagen 1 de 2 Accessing LCD Screen: paso 5, imagen 2 de 2
      • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
      Pregunta a FixBot
      Agregar Comentario
    1. Accessing LCD Screen, LCD: paso 6, imagen 1 de 2 Accessing LCD Screen, LCD: paso 6, imagen 2 de 2
      • On the front of the camera, in battery case, remove screws indicated:
      • Two black 2.05mm Phillips #00 screws
      Pregunta a FixBot
      Agregar Comentario
    2. Accessing LCD Screen: paso 7, imagen 1 de 2 Accessing LCD Screen: paso 7, imagen 2 de 2
      • Flip the camera over to the backside and remove screws indicated:
      • The screw circled in red is a longer black 3.00mm Phillips #00 screw
      • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
      Pregunta a FixBot
      Agregar Comentario
    3. Accessing LCD Screen: paso 8, imagen 1 de 1
      • Pull the cover plate off for the two power cord jacks.
      Pregunta a FixBot
      Agregar Comentario
    4. Accessing LCD Screen: paso 9, imagen 1 de 3 Accessing LCD Screen: paso 9, imagen 2 de 3 Accessing LCD Screen: paso 9, imagen 3 de 3
      • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
      Pregunta a FixBot
      Agregar Comentario
    5. Accessing LCD Screen: paso 10, imagen 1 de 1
      • Remove the orange tape on top of the SD cardholder.
      Pregunta a FixBot
      Agregar Comentario
    6. Accessing LCD Screen: paso 11, imagen 1 de 3 Accessing LCD Screen: paso 11, imagen 2 de 3 Accessing LCD Screen: paso 11, imagen 3 de 3
      • Open the battery cover and lift plastic piece off.
      Pregunta a FixBot
      Agregar Comentario
    7. Accessing LCD Screen: paso 12, imagen 1 de 1
      • Remove tape on left side of camera.
      Pregunta a FixBot
      Agregar Comentario
    8. Accessing LCD Screen: paso 13, imagen 1 de 1
      • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
      Pregunta a FixBot
      Agregar Comentario
    9. Accessing LCD Screen: paso 14, imagen 1 de 1
      • Remove top left LCD bracket.
      • This is a small piece, be careful not to lose it.
      Pregunta a FixBot
      Agregar Comentario
    10. Accessing LCD Screen: paso 15, imagen 1 de 2 Accessing LCD Screen: paso 15, imagen 2 de 2
      • Push down bottom left LCD bracket to release the LCD from grip.
      Pregunta a FixBot
      Agregar Comentario
    11. Accessing LCD Screen: paso 16, imagen 1 de 1
      • Gently lift up LCD screen.
      Pregunta a FixBot
      Agregar Comentario
    12. Accessing LCD Screen: paso 17, imagen 1 de 3 Accessing LCD Screen: paso 17, imagen 2 de 3 Accessing LCD Screen: paso 17, imagen 3 de 3
      • Slowly pull LCD screen to the left to remove it from the other grips.
      • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 4-29, Regan Winter 2011 Miembro de Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 31
Todo El Tiempo: 1,551
