Saltar al contenido principal
Access to RAM and CPU from why! W253EU
Qué necesitas
  1. Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: paso 1, imagen 1 de 3 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: paso 1, imagen 2 de 3 Access to RAM and CPU from why! W253EU, Battery from why! Remove W253EU: paso 1, imagen 3 de 3
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: paso 2, imagen 1 de 2 Access to RAM and CPU from why! W253EU, Access to RAM and CPU from why! W253EU: paso 2, imagen 2 de 2
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. Access to RAM and CPU from why! W253EU: paso 3, imagen 1 de 3 Access to RAM and CPU from why! W253EU: paso 3, imagen 2 de 3 Access to RAM and CPU from why! W253EU: paso 3, imagen 3 de 3
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. Access to RAM and CPU from why! W253EU: paso 4, imagen 1 de 1
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
Conclusión
For reassembly, follow the instructions in reverse order.
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
33,538 Reputación
283 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 354
