Saltar al contenido principal
Access to Housing in the Ulco Integrus PSV
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
    • Before disassembly, make sure the front wheel breaks are on.
    • Make sure ALL gas supplies are disconnected and the system has been purged, and make sure all electrical supplies have been disconnected.
  1. Access to Housing in the Ulco Integrus PSV: paso 4, imagen 1 de 1
    • With one hand on the ventilator removal handle and one holding the lower half of the ventilator, pull up firmly on the handle so that the mounting slides up the slots in the frame.
  2. Access to Housing in the Ulco Integrus PSV: paso 5, imagen 1 de 1
    • Pull the ventilator housing towards you so that the mounting tabs come out of the frame slots rest the ventilator housing on the plastic skirt at the rear of the workstation as shown in the photo.
Conclusión
Jake Lane
Miembro Desde 04/22/19
489 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S7-G13, Paton Spring 2020 Miembro de Cal Poly, Team S7-G13, Paton Spring 2020
CPSU-PATON-S20S7G13
Miembros de 3
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 66
