Saltar al contenido principal
AYL SoundFit Motherboard Replacement
Qué necesitas
  1. AYL SoundFit Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Motherboard Replacement: paso 2, imagen 1 de 1
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Motherboard Replacement: paso 3, imagen 1 de 1
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Motherboard Replacement: paso 4, imagen 1 de 2 AYL SoundFit Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Motherboard Replacement: paso 5, imagen 1 de 1
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Motherboard Replacement: paso 6, imagen 1 de 3 AYL SoundFit Motherboard Replacement: paso 6, imagen 2 de 3 AYL SoundFit Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
Conclusión
3 personas más completaron esta guía.
john
Miembro Desde 03/10/16
171 Reputación
1 Guía escrita
Equipo
IUPUI, Team 3-3, Harley Spring 2016 Miembro de IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Miembros
5 Guías creadas
3 comentarios
Where do u get a new motherboard at?
calvinsmith522 - Contestar
Anybody know where to get a motherboard?
David Whitman - Contestar
Where do I get a motherboard?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 1,547
