Saltar al contenido principal
AYL SoundFit Battery Replacement
Qué necesitas
  1. AYL SoundFit Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
  2. AYL SoundFit Battery Replacement: paso 2, imagen 1 de 1
    • Place a spudger between the black plastic cover and the green case.
    • Pry the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Battery Replacement: paso 3, imagen 1 de 1
    • Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
    • Pry the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Battery Replacement: paso 4, imagen 1 de 2 AYL SoundFit Battery Replacement: paso 4, imagen 2 de 2
    • Remove the two Phillips #00 screws securing the battery casing.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Battery Replacement: paso 5, imagen 1 de 1
    • Desolder the positive and negative battery contacts from the motherboard.
    • Remove the battery from the device.
Conclusión
Dustin Moore
Miembro Desde 02/16/16
108 Reputación
1 Guía escrita
Equipo
IUPUI, Team 3-3, Harley Spring 2016 Miembro de IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Miembros
5 Guías creadas
4 comentarios
Which battery is this, and what is the mAH?
jlongsa - Contestar
3.7V 1500mAh, 5.55Wh
Coba Farr -
The charger works but it does not say chargeing
Zaira Cortes - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 33
Todo El Tiempo: 2,751
