Introducción
You may need to replace the speaker if you are unable to hear people from the other side of the line consistently. The speaker is glued on to the inside of the phone, so you may need to use a superglue or something similar to reattach the new speaker.
Qué necesitas
Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
Una persona más ha completado esta guía.
