Saltar al contenido principal
ATT Trimline 210M Key Pad Replacement
Qué necesitas
  1. ATT Trimline 210M Key Pad Replacement, ATT Trimline 210M Back Cover Disassembly: paso 1, imagen 1 de 1
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
  2. ATT Trimline 210M Key Pad Replacement: paso 2, imagen 1 de 1
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
  3. ATT Trimline 210M Key Pad Replacement: paso 3, imagen 1 de 1
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
  4. ATT Trimline 210M Key Pad Replacement: paso 4, imagen 1 de 1
    • You will have the motherboard and speaker exposed to you.
  5. ATT Trimline 210M Key Pad Replacement, ATT Trimline 210M Motherboard Disassembly: paso 5, imagen 1 de 1
    • Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
  6. ATT Trimline 210M Key Pad Replacement: paso 6, imagen 1 de 1
    • Carefully move the motherboard up to remove it.
  7. ATT Trimline 210M Key Pad Replacement, Key Pad: paso 7, imagen 1 de 1
    • Remove the speaker volume switch before trying to separate the keypad
  8. ATT Trimline 210M Key Pad Replacement: paso 8, imagen 1 de 1
    • Carefully push the black tabs back to dislodge the motherboard.
  9. ATT Trimline 210M Key Pad Replacement: paso 9, imagen 1 de 1
    • Remove keypad bundle.
Conclusión
3 personas más completaron esta guía.
Corey
Miembro Desde 02/10/16
343 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 4-2, Lacy Spring 2016 Miembro de USF Tampa, Team 4-2, Lacy Spring 2016
USFT-LACY-S16S4G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 445
