Saltar al contenido principal
ATT Trek HD9020A Motherboard Replacement
Qué necesitas
  1. ATT Trek HD9020A Motherboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
  2. ATT Trek HD9020A Motherboard Replacement: paso 2, imagen 1 de 1
    • Pull the screen away from the back panel.
  3. ATT Trek HD9020A Motherboard Replacement, Battery: paso 3, imagen 1 de 2 ATT Trek HD9020A Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
  4. ATT Trek HD9020A Motherboard Replacement: paso 4, imagen 1 de 2 ATT Trek HD9020A Motherboard Replacement: paso 4, imagen 2 de 2
    • Use the plastic opening tool to disconnect the black battery connector.
    • Gently lift the battery out of the device.
  5. ATT Trek HD9020A Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 ATT Trek HD9020A Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
  6. ATT Trek HD9020A Motherboard Replacement: paso 6, imagen 1 de 2 ATT Trek HD9020A Motherboard Replacement: paso 6, imagen 2 de 2
    • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
  7. ATT Trek HD9020A Motherboard Replacement: paso 7, imagen 1 de 1
    • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
  8. ATT Trek HD9020A Motherboard Replacement: paso 8, imagen 1 de 2 ATT Trek HD9020A Motherboard Replacement: paso 8, imagen 2 de 2
    • Use angled tweezers to pry up the black tab.
    • Use the angled tweezers to pull out the gold connector.
  9. ATT Trek HD9020A Motherboard Replacement: paso 9, imagen 1 de 2 ATT Trek HD9020A Motherboard Replacement: paso 9, imagen 2 de 2
    • Use the angled tweezers to disconnect the gold connector.
  10. ATT Trek HD9020A Motherboard Replacement: paso 10, imagen 1 de 1
    • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
  11. ATT Trek HD9020A Motherboard Replacement: paso 11, imagen 1 de 2 ATT Trek HD9020A Motherboard Replacement: paso 11, imagen 2 de 2
    • Use the plastic opening tool to lift the motherboard out of place.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 175
