Saltar al contenido principal
ATT Trek HD Screen Digitizer Replacement
Qué necesitas
  1. ATT Trek HD Screen Digitizer Replacement, Back Cover: paso 1, imagen 1 de 1
    • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
  2. ATT Trek HD Screen Digitizer Replacement: paso 2, imagen 1 de 1
    • Pull the screen away from the back panel.
  3. ATT Trek HD Screen Digitizer Replacement, Battery: paso 3, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement, Battery: paso 3, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
  4. ATT Trek HD Screen Digitizer Replacement: paso 4, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 4, imagen 2 de 2
    • Use the plastic opening tool to disconnect the black battery connector.
    • Gently lift the battery out of the device.
  5. ATT Trek HD Screen Digitizer Replacement, Motherboard: paso 5, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement, Motherboard: paso 5, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
  6. ATT Trek HD Screen Digitizer Replacement: paso 6, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 6, imagen 2 de 2
    • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
  7. ATT Trek HD Screen Digitizer Replacement: paso 7, imagen 1 de 1
    • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
  8. ATT Trek HD Screen Digitizer Replacement: paso 8, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    $3.99
    • Use angled tweezers to pry up the black tab.
    • Use the angled tweezers to pull out the gold connector.
  9. ATT Trek HD Screen Digitizer Replacement: paso 9, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 9, imagen 2 de 2
    • Use the angled tweezers to disconnect the gold connector.
  10. ATT Trek HD Screen Digitizer Replacement: paso 10, imagen 1 de 1
    • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
  11. ATT Trek HD Screen Digitizer Replacement: paso 11, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 11, imagen 2 de 2
    • Use the plastic opening tool to lift the motherboard out of place.
  12. ATT Trek HD Screen Digitizer Replacement, Front Camera: paso 12, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement, Front Camera: paso 12, imagen 2 de 2
    $3.99
  13. ATT Trek HD Screen Digitizer Replacement, Screen: paso 13, imagen 1 de 3 ATT Trek HD Screen Digitizer Replacement, Screen: paso 13, imagen 2 de 3 ATT Trek HD Screen Digitizer Replacement, Screen: paso 13, imagen 3 de 3
    • Use the Phillips #00 screwdriver to remove the six 3 mm screws holding the black plastic corner pieces in place.
    • Gently lift the black corner pieces out of the device.
  14. ATT Trek HD Screen Digitizer Replacement: paso 14, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 14, imagen 2 de 2
    $3.99
    • Use the angled tweezers to remove the black cables on each side of the device from their groove.
  15. ATT Trek HD Screen Digitizer Replacement: paso 15, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 15, imagen 2 de 2
    • Use the plastic opening tool to disconnect the black cable connectors from each side of the device.
  16. ATT Trek HD Screen Digitizer Replacement: paso 16, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 16, imagen 2 de 2
    • Remove the remaining ten 3 mm Phillips #00 screws.
  17. ATT Trek HD Screen Digitizer Replacement: paso 17, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 17, imagen 2 de 2
    • Use the plastic opening tool to disconnect the remaining three gold connectors at the bottom of the device.
  18. ATT Trek HD Screen Digitizer Replacement: paso 18, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 18, imagen 2 de 2
    • Use the plastic opening tool to pry up the grey plastic panel.
  19. ATT Trek HD Screen Digitizer Replacement: paso 19, imagen 1 de 2 ATT Trek HD Screen Digitizer Replacement: paso 19, imagen 2 de 2
    • Use the plastic opening tool to pry the screen out of the device.
  20. ATT Trek HD Screen Digitizer Replacement, Screen Digitizer: paso 20, imagen 1 de 3 ATT Trek HD Screen Digitizer Replacement, Screen Digitizer: paso 20, imagen 2 de 3 ATT Trek HD Screen Digitizer Replacement, Screen Digitizer: paso 20, imagen 3 de 3
    • Use the plastic opening tool to pry the charging board away from the digitizer.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 242
