Saltar al contenido principal
ATT EL52300 Battery Replacement
  1. ATT EL52300 Battery Replacement, Battery: paso 1, imagen 1 de 2 ATT EL52300 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 Battery Replacement: paso 2, imagen 1 de 1
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
Conclusión
Katty
Miembro Desde 08/27/15
313 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 1-1, Sullivan Spring 2016 Miembro de USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 887
