Saltar al contenido principal
ATT CL4940 Motherboard Replacement
Qué necesitas
  1. ATT CL4940 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 ATT CL4940 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Disconnect the phone line and power cord from the back cover of the device.
    • Disconnect the phone cable from the side of the device.
  2. ATT CL4940 Motherboard Replacement: paso 2, imagen 1 de 1
    • Turn the device over on its front so the back cover is facing you.
    • Use a bit driver to remove all five 4mm X 10mm Phillips head screws from the back cover.
  3. ATT CL4940 Motherboard Replacement: paso 3, imagen 1 de 3 ATT CL4940 Motherboard Replacement: paso 3, imagen 2 de 3 ATT CL4940 Motherboard Replacement: paso 3, imagen 3 de 3
    • Using a metal spudger, start at the bottom of the device to separate the top cover from the back cover.
    • Work the spudger between the top and back covers of the device starting downwards, then to each side, and finally upwards.
    • There are brackets every few inches along the edge of the device which may be difficult to pull apart.
    • The top and back cover will separate and the internals will be accessible.
  4. ATT CL4940 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use a bit driver to remove all five 5mm X 5mm Phillips head Motherboard screws.
  5. ATT CL4940 Motherboard Replacement: paso 5, imagen 1 de 2 ATT CL4940 Motherboard Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Desoldering Pump
    $3.99
    Comprar
    • Lift the motherboard upwards as shown in the first image.
    • Use a de-soldering pump to disconnect the electric wires by de-soldering them.
Conclusión
Hongkun Zhu
Miembro Desde 09/16/15
263 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-2, Harley Spring 2016 Miembro de IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Miembros
8 Guías creadas
Un comentario
But no option for ordering a replacement motherboard! Did the author get the part off of a scrapped unit?
Bruce England - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 552
