Saltar al contenido principal
ATT CL4940 Internal Speaker Replacement
Qué necesitas
  1. ATT CL4940 Internal Speaker Replacement, Internal Speaker: paso 1, imagen 1 de 2 ATT CL4940 Internal Speaker Replacement, Internal Speaker: paso 1, imagen 2 de 2
    • Unplug your device before beginning disassembly.
    • Remove phone line and power cord from the back cover of the device.
    • Remove phone cable from the side of the device.
  2. ATT CL4940 Internal Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Speaker Replacement: paso 3, imagen 1 de 3 ATT CL4940 Internal Speaker Replacement: paso 3, imagen 2 de 3 ATT CL4940 Internal Speaker Replacement: paso 3, imagen 3 de 3
    • Starting from the bottom of the device, use a metal spudger, separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Speaker Replacement: paso 4, imagen 1 de 1
    • Using wire cutters, sever both the red and black wires connected to the speaker.
    • Carefully remove the speaker from the assembly.
    • Be sure to remove the rubber gasket from the broken speaker. You will need this for reassembly.
Conclusión
Charles Moore
Miembro Desde 02/16/16
201 Reputación
2 Guías creadas
Equipo
IUPUI, Team 2-2, Harley Spring 2016 Miembro de IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 368
