Saltar al contenido principal
ATT CL4940 Internal Microphone Replacement
Qué necesitas
  1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: paso 1, imagen 1 de 2 ATT CL4940 Internal Microphone Replacement, Internal Microphone: paso 1, imagen 2 de 2
    • Unplug your device before beginning disassembly.
    • Remove the phone line and the power cord from the back of the device.
    • Remove the phone cable from the side of the device.
  2. ATT CL4940 Internal Microphone Replacement: paso 2, imagen 1 de 1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Microphone Replacement: paso 3, imagen 1 de 3 ATT CL4940 Internal Microphone Replacement: paso 3, imagen 2 de 3 ATT CL4940 Internal Microphone Replacement: paso 3, imagen 3 de 3
    • Starting from the bottom of the device, (using a metal spudger) separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Microphone Replacement: paso 4, imagen 1 de 1
    • Using wire cutters, sever both the red and the black wires connected to the microphone.
    • To remove the microphone from the device, gently wiggle it while pulling it apart.
Conclusión
Charles Moore
Miembro Desde 02/16/16
201 Reputación
2 Guías creadas
Equipo
IUPUI, Team 2-2, Harley Spring 2016 Miembro de IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Miembros
8 Guías creadas
Un comentario
I'd rather install a new microphone instead of just reinstalling the old one.
Is there a link to where a new microphone can be purchased?
rpoland - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 19
Todo El Tiempo: 647
