Saltar al contenido principal
ATT CL2940 Speakerphone Replacement
Qué necesitas
  1. ATT CL2940 Speakerphone Replacement, Back Panel: paso 1, imagen 1 de 3 ATT CL2940 Speakerphone Replacement, Back Panel: paso 1, imagen 2 de 3 ATT CL2940 Speakerphone Replacement, Back Panel: paso 1, imagen 3 de 3
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Speakerphone Replacement: paso 2, imagen 1 de 3 ATT CL2940 Speakerphone Replacement: paso 2, imagen 2 de 3 ATT CL2940 Speakerphone Replacement: paso 2, imagen 3 de 3
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Speakerphone Replacement: paso 3, imagen 1 de 1
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Speakerphone Replacement, Speakerphone: paso 4, imagen 1 de 2 ATT CL2940 Speakerphone Replacement, Speakerphone: paso 4, imagen 2 de 2
    • Remove the front panel of the device as shown.
  5. ATT CL2940 Speakerphone Replacement: paso 5, imagen 1 de 3 ATT CL2940 Speakerphone Replacement: paso 5, imagen 2 de 3 ATT CL2940 Speakerphone Replacement: paso 5, imagen 3 de 3
    • Desolder the speakerphone with a soldering iron.
    • If you are unfamiliar with solder, check out the article on soldering and be very careful. The iron is hot!
  6. ATT CL2940 Speakerphone Replacement: paso 6, imagen 1 de 2 ATT CL2940 Speakerphone Replacement: paso 6, imagen 2 de 2
    • Use the soldering iron to reconnect the wires to the new speaker.
    • Place the new speaker back in place.
    • Make sure that all of the components are back in place.
Linea de Meta
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 1-1, Harley Spring 2016 Miembro de IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Miembros
13 Guías creadas
Un comentario
Why do all these repairs require NO PARTS to replace defective parts?
And, of course< there is no links to a place to purchase the needed parts...
rpoland - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 619
