Saltar al contenido principal
ATT CL2940 Handset Speaker Replacement
Qué necesitas
  1. ATT CL2940 Handset Speaker Replacement, Handset Speaker: paso 1, imagen 1 de 2 ATT CL2940 Handset Speaker Replacement, Handset Speaker: paso 1, imagen 2 de 2
    • Separate the two sections of the handset by pushing them apart with the tip of the metal spudger or opening tool.
  2. ATT CL2940 Handset Speaker Replacement: paso 2, imagen 1 de 2 ATT CL2940 Handset Speaker Replacement: paso 2, imagen 2 de 2
    • Continue separating the two sections by using the metal spudger all the way around the edge of the handset.
  3. ATT CL2940 Handset Speaker Replacement: paso 3, imagen 1 de 1
    • After separating the two sections of the handset, it should look as shown.
  4. ATT CL2940 Handset Speaker Replacement: paso 4, imagen 1 de 3 ATT CL2940 Handset Speaker Replacement: paso 4, imagen 2 de 3 ATT CL2940 Handset Speaker Replacement: paso 4, imagen 3 de 3
    • Pull the speaker out gently to detach it from the handset. The speaker is located at the top end of the handset. It is the circular white piece with red and greed wires connected to it.
    • The speaker is attached to the handset with a slightly sticky adhesive.
  5. ATT CL2940 Handset Speaker Replacement: paso 5, imagen 1 de 2 ATT CL2940 Handset Speaker Replacement: paso 5, imagen 2 de 2
    • Use a soldering iron to melt the existing solder off of both the red and green wires in order to completely remove the speaker.
Conclusión
Una persona más ha completado esta guía.
Noor Assaf
Miembro Desde 02/15/16
309 Reputación
2 Guías creadas
Equipo
IUPUI, Team 1-1, Harley Spring 2016 Miembro de IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 665
