Saltar al contenido principal
  1. Take new watch strap and springbars, insert one side into the hole on watch case. Using the 1.5mm flat head screwdriver compress the spring bar until you can slide the band in between the bars on the watch case. Using the 1.5mm flat head screwdriver compress the spring bar until you can slide the band in between the bars on the watch case.
    • Take new watch strap and springbars, insert one side into the hole on watch case.
    • Using the 1.5mm flat head screwdriver compress the spring bar until you can slide the band in between the bars on the watch case.
Linea de Meta
Steven Miller
Miembro Desde 10/02/16
109 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-3, Sullivan Spring 2016 Miembro de USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 315
