Introducción
Step-by-step guide in removing and replacing a faulty motherboard.
Qué necesitas
On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Use the T5 Torx driver to remove the four screws on the case.
The case will pry easily off with just gentle hand pressure
3 personas más completaron esta guía.
Un comentario
Where could i get the new replacement motherboard for that? Please inform.. thanks :)
