Saltar al contenido principal
ASUS ZenWatch Battery Replacement
Qué necesitas
  1. ASUS ZenWatch Battery Replacement, Watch Strap Removal: paso 1, imagen 1 de 2 ASUS ZenWatch Battery Replacement, Watch Strap Removal: paso 1, imagen 2 de 2
    • On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
  2. ASUS ZenWatch Battery Replacement, Battery: paso 2, imagen 1 de 3 ASUS ZenWatch Battery Replacement, Battery: paso 2, imagen 2 de 3 ASUS ZenWatch Battery Replacement, Battery: paso 2, imagen 3 de 3
    • Use the T5 Torx driver to remove the four screws on the case.
    • Use the magnetic pad to keep all your parts easily contained!
    • The case will pry easily off with just gentle hand pressure
  3. ASUS ZenWatch Battery Replacement: paso 3, imagen 1 de 2 ASUS ZenWatch Battery Replacement: paso 3, imagen 2 de 2
    • Using the tweezers, gently remove the fabric protecting the battery connection.
    • Take care when removing the fabric. Too much force may damage the contact with the metal tweezers.
    • Use the heavy duty spudger to gently push the contact towards the top of the case.
  4. ASUS ZenWatch Battery Replacement: paso 4, imagen 1 de 3 ASUS ZenWatch Battery Replacement: paso 4, imagen 2 de 3 ASUS ZenWatch Battery Replacement: paso 4, imagen 3 de 3
    • Gently pry the battery up with the plastic pry tools
Conclusión
13 personas más completaron esta guía.
Wayne McClure
Miembro Desde 02/10/16
961 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-3, Sullivan Spring 2016 Miembro de USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Miembros
7 Guías creadas
5 comentarios
Where could i find the modul replacement for asus zenwatch edition (1st editio) the chip body…thanks :) Dave
Davy Jones - Contestar
Dónde puedo adquirir esta batería en Colombia
Jhon Jairo Piza Puerta - Contestar
I want to find a battery for zenwatch 1 plz help i still have a fully functioning zenwatch I don’t want to waste it. (pref na or even better Canadian the shipping is murder)
wing_0_delta - Contestar
Hi
im looking for a battery für Asus Viviwatch. Is ist the same as in ZenWatch?
mhoechtl - Contestar
Looking to get zenwatch 1 battery. Any source recommended by anyone?
fine_pears - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 13,821
