Saltar al contenido principal
ASUS ZenPad S 8.0 Front Facing Camera Replacement
Qué necesitas
  1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: paso 1, imagen 1 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: paso 1, imagen 2 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: paso 1, imagen 3 de 3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: paso 2, imagen 1 de 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: paso 2, imagen 2 de 2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Front Facing Camera Replacement: paso 3, imagen 1 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: paso 3, imagen 2 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: paso 3, imagen 3 de 3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Front Facing Camera Replacement: paso 4, imagen 1 de 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: paso 4, imagen 2 de 2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: paso 5, imagen 1 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: paso 5, imagen 2 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: paso 5, imagen 3 de 3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Front Facing Camera Replacement: paso 6, imagen 1 de 1
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
Conclusión
John Astfanous
Miembro Desde 10/04/16
987 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-2, Cagle Fall 2016 Miembro de USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 1,332
