Saltar al contenido principal
ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement
Qué necesitas
  1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: paso 1, imagen 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: paso 1, imagen 2 de 2
    • Flip the laptop over so the model stickers face the ceiling.
  2. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: paso 2, imagen 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Remove eleven 7mm Phillips #00 screws that secure the back cover.
    • Two screws are under the rubber pad.
  3. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: paso 3, imagen 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Using a spudger, carefully remove the back cover.
  4. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: paso 4, imagen 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the six 3mm Phillips #00 screws holding the battery in place.
  5. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: paso 5, imagen 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Disconnect the battery wires from the motherboard by pulling on the black tab using a spudger or your hands.
  6. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Carefully lift the battery up and out of the laptop.
  7. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: paso 7, imagen 1 de 3 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: paso 7, imagen 2 de 3 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: paso 7, imagen 3 de 3
    • Remove four 3 mm Phillips screws (two on each side) holding the hard drive in the frame
  8. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: paso 8, imagen 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: paso 8, imagen 2 de 2
    • Grip the side of the hard drive and slide it out of the device.
Conclusión
Una persona más ha completado esta guía.
Joshua Letizia
Miembro Desde 10/30/19
193 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 551
