Introducción
This guide will demonstrate how to replace the Speaker/Charger Port/Headphone Jack of a Zenfone 3. This may be necessary if these functions no longer work as normal. For this guide, you will need the tweezers, Torx T2 screwdriver, a prying tool, and the Phillips #00 screwdriver.
Qué necesitas
Using a pair of tweezers, pull put the SIM card tray and set it to the side.
Remove all screws 3mm, using the Phillips #00 screwdriver, at the bottom of the device.
Una persona más ha completado esta guía.
