Saltar al contenido principal
Introducción
This guide will demonstrate how to replace the front camera of a Zenfone 3. This may be necessary if the camera no longer displays a picture or displays a distorted picture. For this guide, you will need the tweezers, Torx T2 screwdriver, a prying tool, and the Phillips #00 screwdriver.
  1. Using a pair of tweezers, pull put the SIM card tray and set it to the side. Using a pair of tweezers, pull put the SIM card tray and set it to the side.
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. Remove the two 2 mm screws using a Torx T2 screwdriver.
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone. There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. Peel back the silver tape.
    • Peel back the silver tape.
  6. Disconnect the battery connections.
    • Disconnect the battery connections.
  7. Pry and remove the battery.
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  8. Peel the copper adhesive off.
    • Peel the copper adhesive off.
  9. Unplug the front camera. Unplug the front camera. Unplug the front camera.
    • Unplug the front camera.
Conclusión
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 10
Todo El Tiempo: 239
