Saltar al contenido principal
ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement
Qué necesitas
  1. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement, Battery: paso 1, imagen 1 de 2 ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement, Battery: paso 1, imagen 2 de 2
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: paso 2, imagen 1 de 1
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: paso 3, imagen 1 de 2 ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: paso 3, imagen 2 de 2
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: paso 4, imagen 1 de 1
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: paso 5, imagen 1 de 1
    • Peel back the silver tape.
  6. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: paso 6, imagen 1 de 1
    • Disconnect the battery connections.
  7. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: paso 7, imagen 1 de 1
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  8. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement, Fingerprint Scanner: paso 8, imagen 1 de 1
    • Unplug the wire connecting the two large pieces of the device. Next, seperate the two halves of the phone.
  9. ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: paso 9, imagen 1 de 3 ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: paso 9, imagen 2 de 3 ASUS ZENFONE 3 Zoom Fingerprint Scanner Replacement: paso 9, imagen 3 de 3
    • Using the plastic opening tool, pry the fingerprint scanner out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 663
