Saltar al contenido principal
ASUS X552LAV-BBI5N08 CD Drive Replacement
Qué necesitas
  1. ASUS X552LAV-BBI5N08 CD Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 2, imagen 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 2, imagen 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 2, imagen 3 de 3
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 CD Drive Replacement, CD Drive: paso 3, imagen 1 de 1
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 4, imagen 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 4, imagen 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 4, imagen 3 de 3
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
  5. ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 5, imagen 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 5, imagen 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 5, imagen 3 de 3
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 6, imagen 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 6, imagen 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 6, imagen 3 de 3
    • Use Tri-wing Y1 screwdriver to remove seven 4mm screws from battery area.
    • Use opening tool to split keyboard from base of the laptop.
    • Make sure to start from one end and go around the edges.
  7. ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 7, imagen 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 7, imagen 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 7, imagen 3 de 3
    • Flip laptop to sit on its bottom.
    • Lift keyboard up by the front edge
  8. ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 8, imagen 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 8, imagen 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 8, imagen 3 de 3
    • Flip up the small locking flap for the two ZIF connectors.
    • Unplug the connectors that are keeping the keyboard connected.
  9. ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 9, imagen 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 9, imagen 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 9, imagen 3 de 3
    • Flip up the locking flap for the ZIF connector.
    • Unplug the connector that is keeping the keyboard connected.
  10. ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 10, imagen 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 10, imagen 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: paso 10, imagen 3 de 3
    • Remove keyboard from laptop.
    • Remove two 4mm screws around CD drive
    • Slide the CD drive out to the right to remove it.
Conclusión
Jason Vo
Miembro Desde 02/15/18
857 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S17-G1, Boczar Spring 2018 Miembro de USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 261
