Saltar al contenido principal
ASUS X550LB-DS71 Fan Replacement
Qué necesitas
  1. ASUS X550LB-DS71 Fan Replacement, Fan: paso 1, imagen 1 de 3 ASUS X550LB-DS71 Fan Replacement, Fan: paso 1, imagen 2 de 3 ASUS X550LB-DS71 Fan Replacement, Fan: paso 1, imagen 3 de 3
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
  2. ASUS X550LB-DS71 Fan Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
  3. ASUS X550LB-DS71 Fan Replacement: paso 3, imagen 1 de 3 ASUS X550LB-DS71 Fan Replacement: paso 3, imagen 2 de 3 ASUS X550LB-DS71 Fan Replacement: paso 3, imagen 3 de 3
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  4. ASUS X550LB-DS71 Fan Replacement: paso 4, imagen 1 de 2 ASUS X550LB-DS71 Fan Replacement: paso 4, imagen 2 de 2
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
  5. ASUS X550LB-DS71 Fan Replacement: paso 5, imagen 1 de 2 ASUS X550LB-DS71 Fan Replacement: paso 5, imagen 2 de 2
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
  6. ASUS X550LB-DS71 Fan Replacement: paso 6, imagen 1 de 2 ASUS X550LB-DS71 Fan Replacement: paso 6, imagen 2 de 2
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
  7. ASUS X550LB-DS71 Fan Replacement: paso 7, imagen 1 de 3 ASUS X550LB-DS71 Fan Replacement: paso 7, imagen 2 de 3 ASUS X550LB-DS71 Fan Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Flip the motherboard to show the underside.
    • Locate the square fan connection attached to the motherboard.
    • Disconnect it using the tweezers (blunt).
  8. ASUS X550LB-DS71 Fan Replacement: paso 8, imagen 1 de 1
    • Remove the black tape from the fan as seen in the marked location.
    • At this point, the fan is now disconnected from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Nathan Dyer
Miembro Desde 09/25/17
550 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S16-G1, Eyestone Fall 2017 Miembro de USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 863
