Introducción
The display monitor is an output device which presents data on the screen. It is what allows the user to see what inputs they are putting into the device.
Qué necesitas
Flip open the laptop with the screen facing towards you.
Using the plastic opening tool, remove the square tape from the marked locations.
Use the Phillips #0 Screwdriver to remove the two 2mm screws from those locations.
Casi Terminas!
Conclusión
