Saltar al contenido principal
ASUS X550LB-DS71 Display Panel Replacement
Qué necesitas
  1. ASUS X550LB-DS71 Display Panel Replacement, Display Panel: paso 1, imagen 1 de 3 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: paso 1, imagen 2 de 3 ASUS X550LB-DS71 Display Panel Replacement, Display Panel: paso 1, imagen 3 de 3
    • Flip open the laptop with the screen facing towards you.
    • Using the plastic opening tool, remove the square tape from the marked locations.
    • Use the Phillips #0 Screwdriver to remove the two 2mm screws from those locations.
  2. ASUS X550LB-DS71 Display Panel Replacement: paso 2, imagen 1 de 2 ASUS X550LB-DS71 Display Panel Replacement: paso 2, imagen 2 de 2
    • Using the plastic opening tool, open the front cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  3. ASUS X550LB-DS71 Display Panel Replacement: paso 3, imagen 1 de 3 ASUS X550LB-DS71 Display Panel Replacement: paso 3, imagen 2 de 3 ASUS X550LB-DS71 Display Panel Replacement: paso 3, imagen 3 de 3
    • Peel off the tape located on the left and right side of the display monitor.
    • Use the Phillips #0 screwdriver to remove the screws at the marked locations in each corner of the display.
  4. ASUS X550LB-DS71 Display Panel Replacement: paso 4, imagen 1 de 3 ASUS X550LB-DS71 Display Panel Replacement: paso 4, imagen 2 de 3 ASUS X550LB-DS71 Display Panel Replacement: paso 4, imagen 3 de 3
    • Place the display monitor face down to expose the ribbon connector.
    • Remove the ribbon connector to separate the display monitor from the rest of the device.
Conclusión
Nathan Dyer
Miembro Desde 09/25/17
550 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S16-G1, Eyestone Fall 2017 Miembro de USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 31
Todo El Tiempo: 1,014
