Saltar al contenido principal
ASUS X533SA-BHCLN10 LCD Screen Replacement
Qué necesitas
Resumen del Video
  1. ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 2 ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 2
    • Power off laptop.
    • Flip over the laptop so the model stickers are pointing towards the ceiling, and the back of the laptop is facing you.
  2. ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 2, imagen 1 de 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 2, imagen 2 de 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 2, imagen 3 de 3
    • Carefully insert a plastic opening tool into the top edge of the plastic cover. Slowly run the tool along the top edge to allow several small plastic clips to release.
    • Lift the plastic cover off and set it aside.
  3. ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 3, imagen 1 de 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 3, imagen 2 de 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 3, imagen 3 de 3
    • Using tweezers, remove the (2) two magnetic tabs covering the screws on the screen.
  4. ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 4, imagen 1 de 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 4, imagen 2 de 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 4, imagen 3 de 3
    • Use a JIS #0 screwdriver to remove the two 4.5mm screws.
  5. ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 5, imagen 1 de 2 ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 5, imagen 2 de 2
    • Insert a plastic opening tool under the edge of the laptop lid.
    • Carefully pop out the sides of the laptop by running the plastic opening tool along the edge.
  6. ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 6, imagen 1 de 2 ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Use a JIS #0 screwdriver to unscrew the four 3.5mm screws.
  7. ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 7, imagen 1 de 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 7, imagen 2 de 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: paso 7, imagen 3 de 3
    • Carefully lift up the LCD screen.
    • Carefully remove the cable connecting the LCD to the laptop by popping up the white clip on the laptop and sliding the connector out.
Conclusión
Spencer Lee
Miembro Desde 11/01/18
268 Reputación
2 Guías creadas
Equipo
IUPUI, Team S2-G4, Harley Fall 2018 Miembro de IUPUI, Team S2-G4, Harley Fall 2018
IUPUI-HARLEY-F18S2G4
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 521
