Saltar al contenido principal
ASUS X533SA-BHCLN10 Fan Replacement
Qué necesitas
  1. ASUS X533SA-BHCLN10 Fan Replacement, Battery: paso 1, imagen 1 de 2 ASUS X533SA-BHCLN10 Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
  2. ASUS X533SA-BHCLN10 Fan Replacement: paso 2, imagen 1 de 2 ASUS X533SA-BHCLN10 Fan Replacement: paso 2, imagen 2 de 2
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
  3. ASUS X533SA-BHCLN10 Fan Replacement: paso 3, imagen 1 de 2 ASUS X533SA-BHCLN10 Fan Replacement: paso 3, imagen 2 de 2
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
  4. ASUS X533SA-BHCLN10 Fan Replacement, Fan: paso 4, imagen 1 de 3 ASUS X533SA-BHCLN10 Fan Replacement, Fan: paso 4, imagen 2 de 3 ASUS X533SA-BHCLN10 Fan Replacement, Fan: paso 4, imagen 3 de 3
    • Remove the three 5.5mm screws shown in the picture using the Phillips #0 screwdriver.
    • Carefully push the white connector out of the slot.
    • After removing the black electrical tape hold on to the side of the fan and lightly pull on the wire to remove the fan.
  5. ASUS X533SA-BHCLN10 Fan Replacement: paso 5, imagen 1 de 1
    • Remove the fan completely . attach electrical tape on the new fan for replacement.
Conclusión
Edmund Lee
Miembro Desde 09/26/17
473 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S13-G3, Boczar Fall 2017 Miembro de USF Tampa, Team S13-G3, Boczar Fall 2017
USFT-BOCZAR-F17S13G3
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 309
