Introducción
In this guide we will be replacing the fan of this laptop. After finding a replacement be sure to follow this guide carefully to easily and simply replace the fan. This process is a bit more difficult, but be sure to carefully go through the process.
Qué necesitas
Turn over the laptop on the back panel.
Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
Remove the three 5.5mm screws shown in the picture using the Phillips #0 screwdriver.
Carefully push the white connector out of the slot.
After removing the black electrical tape hold on to the side of the fan and lightly pull on the wire to remove the fan.
