Saltar al contenido principal
ASUS X502CA Screen Replacement
Qué necesitas
  1. ASUS X502CA Screen Replacement, Screen: paso 1, imagen 1 de 2 ASUS X502CA Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Remove plastic square covers on both bottom corners exposing the screws below using tweezers.
    • Remove the screws under the plastic square covers, using a Phillips #00 screwdriver.
    • Screws are black, 50mm in lenght with a 20mm diameter.
  2. ASUS X502CA Screen Replacement: paso 2, imagen 1 de 2 ASUS X502CA Screen Replacement: paso 2, imagen 2 de 2
    • Remove the trim from the monitor by using the Plastic Opening Tool to carefully pop off the clips around the parameter.
  3. ASUS X502CA Screen Replacement: paso 3, imagen 1 de 2 ASUS X502CA Screen Replacement: paso 3, imagen 2 de 2
    • Remove the four phillips screws (two on top and two on bottom) using the Phillips #00 screwdriver.
    • The screws are black, 45mm long and 15mm in diameter with a philips head
  4. ASUS X502CA Screen Replacement: paso 4, imagen 1 de 2 ASUS X502CA Screen Replacement: paso 4, imagen 2 de 2
    • Pop the screen out from the top and lay flat on the keyboard.
    • Do not pull screen away from keyboard, as it is still attached by a wire at the bottom.
  5. ASUS X502CA Screen Replacement: paso 5, imagen 1 de 2 ASUS X502CA Screen Replacement: paso 5, imagen 2 de 2
    • Peel off the clear tape that is securing the video cable connector using your fingers or tweezers.
  6. ASUS X502CA Screen Replacement: paso 6, imagen 1 de 2 ASUS X502CA Screen Replacement: paso 6, imagen 2 de 2
    • Unplug the screen using tweezers.
  7. ASUS X502CA Screen Replacement: paso 7, imagen 1 de 1
    • Replace the damage screen with a new one.
    • Replacing the bezel trim requires the bottom to be inside the ends of the hinge cover. Be careful not to break the bezel when doing this.
    • Removing the hinge cover has a chance of breaking the tabs that hold it on. Remove it carefully.
Conclusión
3 personas más completaron esta guía.
Anthony Taylor
Miembro Desde 01/28/15
354 Reputación
2 Guías creadas
Equipo
Clemson, Team 14-1, Shirley Winter 2015 Miembro de Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 3,353
