Saltar al contenido principal
ASUS X502CA LED Board Replacement
Qué necesitas
  1. ASUS X502CA LED Board Replacement, Palm Rest with Keyboard and Touch Pad: paso 1, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA LED Board Replacement: paso 2, imagen 1 de 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA LED Board Replacement: paso 3, imagen 1 de 2 ASUS X502CA LED Board Replacement: paso 3, imagen 2 de 2
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA LED Board Replacement: paso 4, imagen 1 de 2 ASUS X502CA LED Board Replacement: paso 4, imagen 2 de 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA LED Board Replacement, LED Board: paso 5, imagen 1 de 3 ASUS X502CA LED Board Replacement, LED Board: paso 5, imagen 2 de 3 ASUS X502CA LED Board Replacement, LED Board: paso 5, imagen 3 de 3
    • Use the plastic opening tool to flip up the small clamp and pull out the ribbon cable.
  6. ASUS X502CA LED Board Replacement: paso 6, imagen 1 de 2 ASUS X502CA LED Board Replacement: paso 6, imagen 2 de 2
    • Use 1 or 2 plastic opening tools to push down the small black plastic clips.
    • Pull the board up and out.
Conclusión
Una persona más ha completado esta guía.
Beau Raymond
Miembro Desde 11/06/18
103 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 213
