Introducción
This guide entails how to quickly and correctly replace the LED board for the lower led lights on the front of an ASUS laptop. The LED board is one of the simplest parts to replace on the inside of the ASUS laptop so don't be intimidated by the task. With the help of this guide you will be able to replace them without a hitch.
Qué necesitas
Use the Phillips #00 screwdriver to remove the seven 90mm screws.
Use the Phillips #00 screwdriver to remove the four 50mm screws.
Use the plastic opening tool to flip up the small clamp and pull out the ribbon cable.
Una persona más ha completado esta guía.
