Saltar al contenido principal
ASUS X502CA Fan Replacement
Qué necesitas
  1. ASUS X502CA Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove:
    • Eight 9 mm screws.
    • Four 5 mm screws.
  2. ASUS X502CA Fan Replacement: paso 2, imagen 1 de 1
    • Remove the keyboard cover panel by using a plastic opening tool to carefully pop off the clips around the perimeter.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Fan Replacement: paso 3, imagen 1 de 1
    • The keyboard cover panel is connected to the motherboard with ribbons; be careful not to damage them.
    • Lift the keyboard cover carefully.
    • Disconnect the keyboard and touch-pad ribbons using tweezers.
  4. ASUS X502CA Fan Replacement: paso 4, imagen 1 de 1
    • Remove the keyboard cover panel.
  5. ASUS X502CA Fan Replacement: paso 5, imagen 1 de 1
    • Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
    • If these are not unplugged, the motherboard may shock you.
  6. ASUS X502CA Fan Replacement: paso 6, imagen 1 de 1
    • Disconnect the remaining connectors using tweezers or your finger nails.
  7. ASUS X502CA Fan Replacement: paso 7, imagen 1 de 1
    • Remove the six 5 mm screws using the Phillips #00 screwdriver.
  8. ASUS X502CA Fan Replacement: paso 8, imagen 1 de 1
    • Flip the motherboard over and away from the screen.
  9. ASUS X502CA Fan Replacement: paso 9, imagen 1 de 1
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  10. ASUS X502CA Fan Replacement: paso 10, imagen 1 de 1
    • Unplug the fan's power connector using tweezers or your fingernails.
  11. ASUS X502CA Fan Replacement: paso 11, imagen 1 de 1
    • Peel off the marked strip using your fingers.
  12. ASUS X502CA Fan Replacement: paso 12, imagen 1 de 1
    • Lift the fan up and away from the motherboard.
Conclusión
6 personas más completaron esta guía.
David Conner
Miembro Desde 03/03/15
292 Reputación
2 Guías creadas
Equipo
Clemson, Team 14-1, Shirley Winter 2015 Miembro de Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Miembros
5 Guías creadas
2 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 7,840
