Introducción
Use this guide to help you replace the motherboard or to get to other parts in the laptop. Don't forget to keep track of all your screws.
Qué necesitas
Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
Lift up the black lock holding the ribbon.
Using the blue tab, pull out the ribbon.
3 personas más completaron esta guía.
