Saltar al contenido principal
ASUS X44H-BBR4 Keyboard Replacement
Qué necesitas
  1. ASUS X44H-BBR4 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 ASUS X44H-BBR4 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Open the laptop to show the keyboard.
  2. ASUS X44H-BBR4 Keyboard Replacement: paso 2, imagen 1 de 1
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
  3. ASUS X44H-BBR4 Keyboard Replacement: paso 3, imagen 1 de 3 ASUS X44H-BBR4 Keyboard Replacement: paso 3, imagen 2 de 3 ASUS X44H-BBR4 Keyboard Replacement: paso 3, imagen 3 de 3
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
  4. ASUS X44H-BBR4 Keyboard Replacement: paso 4, imagen 1 de 2 ASUS X44H-BBR4 Keyboard Replacement: paso 4, imagen 2 de 2
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
  5. ASUS X44H-BBR4 Keyboard Replacement: paso 5, imagen 1 de 2 ASUS X44H-BBR4 Keyboard Replacement: paso 5, imagen 2 de 2
    • Flip the keyboard over to reveal the back of it and what is underneath.
  6. ASUS X44H-BBR4 Keyboard Replacement: paso 6, imagen 1 de 3 ASUS X44H-BBR4 Keyboard Replacement: paso 6, imagen 2 de 3 ASUS X44H-BBR4 Keyboard Replacement: paso 6, imagen 3 de 3
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
  7. ASUS X44H-BBR4 Keyboard Replacement: paso 7, imagen 1 de 1
    • Remove the keyboard completely.
Conclusión
4 personas más completaron esta guía.
Kelly Merlo
Miembro Desde 10/14/15
500 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 4-3, Catania Fall 2015 Miembro de UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 1,177
