Saltar al contenido principal
ASUS X44H-BBR4 Hard Drive Replacement
Qué necesitas
  1. ASUS X44H-BBR4 Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 ASUS X44H-BBR4 Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the device over.
  2. ASUS X44H-BBR4 Hard Drive Replacement: paso 2, imagen 1 de 3 ASUS X44H-BBR4 Hard Drive Replacement: paso 2, imagen 2 de 3 ASUS X44H-BBR4 Hard Drive Replacement: paso 2, imagen 3 de 3
    • Slide the right lock button to the unlock position.
    • After it is unlocked, a red line will be visible.
  3. ASUS X44H-BBR4 Hard Drive Replacement: paso 3, imagen 1 de 2 ASUS X44H-BBR4 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Slide the left lock button into the unlock position and hold.
  4. ASUS X44H-BBR4 Hard Drive Replacement: paso 4, imagen 1 de 3 ASUS X44H-BBR4 Hard Drive Replacement: paso 4, imagen 2 de 3 ASUS X44H-BBR4 Hard Drive Replacement: paso 4, imagen 3 de 3
    • While holding the left lock button in the unlock position, push the battery from the center away from you.
  5. ASUS X44H-BBR4 Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 2 ASUS X44H-BBR4 Hard Drive Replacement, Hard Drive: paso 5, imagen 2 de 2
    • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
  6. ASUS X44H-BBR4 Hard Drive Replacement: paso 6, imagen 1 de 2 ASUS X44H-BBR4 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Once the screws are removed, slide the back panel away from the computer.
  7. ASUS X44H-BBR4 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
  8. ASUS X44H-BBR4 Hard Drive Replacement: paso 8, imagen 1 de 2 ASUS X44H-BBR4 Hard Drive Replacement: paso 8, imagen 2 de 2
    • Slide the hard drive to the left, unlocking it from its default position.
  9. ASUS X44H-BBR4 Hard Drive Replacement: paso 9, imagen 1 de 2 ASUS X44H-BBR4 Hard Drive Replacement: paso 9, imagen 2 de 2
    • Pull the hard drive upwards and take it out of its position.
  10. ASUS X44H-BBR4 Hard Drive Replacement: paso 10, imagen 1 de 3 ASUS X44H-BBR4 Hard Drive Replacement: paso 10, imagen 2 de 3 ASUS X44H-BBR4 Hard Drive Replacement: paso 10, imagen 3 de 3
    • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
  11. ASUS X44H-BBR4 Hard Drive Replacement: paso 11, imagen 1 de 1
    • Pull upwards on the metal casing and it will come off.
Conclusión
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team 4-3, Catania Fall 2015 Miembro de UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,217
